Chris Cilino Posted August 10, 2019 Report Posted August 10, 2019 (edited) Rather than have a bunch of links floating around, I'm creating this "one stop shop" for my contributions to the LabVIEW community. This is my Cilino Suite aka "C Suite". Presentations My YouTube Channel of Presentations (bit.ly/ChrisCilino_Presentations) including: My LabVIEW Champion Interview NIWeek 2018 Keynote Presentation Soliton Customer Testimonial LabVIEW Architect's Forum Q3 2018 - LabVIEW Auto Documentation Software LabVIEW Architect's Forum Q4 2016 - Automated Build Process 2018 Certified LabVIEW Architect Summit - Everything a Software Engineer Needs to Know That Has Nothing to Do with Software Engineering My First Keynote Presentation at VIP Days in Germany Code - Reuse Libraries Automated Build System - Software Module Builder Summary: A system that turns source into exports. The exports can be of any type. Also determines build order of hierarchical modules, updates dependencies, and allows you to move the exports to the location you need for your end users to find and install the export and its dependencies. Download BitBucket Repository: git clone https://ChrisCilino@bitbucket.org/ChrisCilino/software-module-builder.git Dependencies LabVIEW Container (see link below) LabVIEW SCC API Summary: An API designed to abstract server based source code control providers. BitBucket Repository: git clone https://ChrisCilino@bitbucket.org/ChrisCilino/labview-scc-api.git Distributed as a part of the Automated Build system NI Package Manager Build Spec API Summary: An API to programmatically interact with and edit the LabVIEW NI Package Build Specification. BitBucket Repository: git clone https://ChrisCilino@bitbucket.org/ChrisCilino/ni-package-manager-api.git Distributed as a part of the Automated Build system Custom Install Step Launcher Summary: Enables NI Package Manager to execute VIs as a Post-Install/Post-Install All/Pre-Uninstall action. Download: Distributed as a part of the Automated Build system BitBucket Repository: git clone https://ChrisCilino@bitbucket.org/ChrisCilino/custom-install-step-launcher.git Software Module Template - NIPKG and VIP Summary: A template LabVIEW Project designed to be built into an NI Package and VI Package by the Software Module Builder (see above). With this template, a user need only put their code in the "source" directory and edit some build specification information and the build process will do the rest. Distributed with the Software Module Builder BitBucket Repository: git clone https://ChrisCilino@bitbucket.org/ChrisCilino/software-module-template-nipkg-vip.git Watchdog Framework Summary: A software observer of "situations" that can notify when something of "interest" happens. The observer is the "WatchDog", the thing being observed is a "Perpetrator", and the notification is a "bark". Download BitBucket Repository: git clone https://ChrisCilino@bitbucket.org/ChrisCilino/labview-watchdog-framework.git Sequencer Summary: A simple design pattern that organizes code on a single block diagram without the inappropriate/excessive use of subVIs. Download BitBucket Repository: git clone https://ChrisCilino@bitbucket.org/ChrisCilino/sequencer-pattern.git Auto Documentation Summary: Think of this as Doxogen for LabVIEW. Given a Project, Lvlib or .class, this software generates report. The report is "printed" to a confluence page. The software is Object Oriented and designed to be extended through inheritance. Download BitBucket Repository: git clone https://ChrisCilino@bitbucket.org/ChrisCilino/labview-auto-documentation.git Dependencies LabVIEW Atlassian / Confluence / Jira APIs Summary: An API that allows you to control Atlassian assets such as Confluence and JIRA from LabVIEW BitBucket Repository: git clone https://ChrisCilino@bitbucket.org/ChrisCilino/labview-atlassian-api.git LabVIEW Container Summary: A dynamic data structure that combines the strengths of a cluster and an array. Download BitBucket Repository: git clone https://ChrisCilino@bitbucket.org/ChrisCilino/labview-container.git History/Credentials/Social Media LabVIEW Champion Page LinkedIn LabVIEW Champion Badge Certified LabVIEW Architect Badge Twitter NI.com Profile Edited August 24, 2019 by cjcilino 1 Quote
