Panel Actors Launched from non Panel Actor
Just starting looking at MGI's Panel Actors. In the examples, the root actor is always a panel actor and therefore the "Launch  Root Panel.vi" is used. What if you have an application where your root actor is not a panel and you want it to be able to launch a panel actor. Do you just used launch nested panel or do you always have to have a root panel actor? I thought in general you want a single root actor unless you are communicating across network boundaries.
To give you a better idea of what I want to do:
I want:
-Root actor is not a panel actor and launches and sets up some communication and other actors
-Root actor launches a nested panel which is a panel actor that contains a subpanel.
-This nested panel actor launches other panel actors and switches them into the subpanel as needed
Thanks
