HeLo Posted September 16, 2020 Report Share Posted September 16, 2020 As the faddeeva function is not available in LabVIEW, I have compiled the code of Steven G. Johnson into a DLL using the GCC compiler in Code::Blocks - and it works (the same code is used also in SciPy, Matlab and others). In order to improve in speed, I would like to run the function in a for-loop "enabling loop parallelism" or have it called by multiple clones of a reentrant "Faddeeva.vi". However calling the function that way produces erroneous results - it looks like there is some interference between the different calls. As native LabVIEW functions like "Integral x(t).vi" can do exactly this and as these functions also call a dll, I must have some statements in my dll that are not thread save. Can anybody point me to the mistake, that prevents a correct multi threaded call? Herbert P.S.: Please find below a part of the c-file attached #include <math.h> #include <windows.h> /* The Faddeeva.cc file contains macros to let it compile as C code (assuming C99 complex-number support), so just #include it. */ #include "Faddeeva.cc" BOOL WINAPI DllMain (HINSTANCE hInst /* Library instance handle. */ , DWORD reason /* Reason this function is being called. */ , LPVOID reserved /* Not used. */ ) { switch (reason) { case DLL_PROCESS_ATTACH: break; case DLL_PROCESS_DETACH: break; case DLL_THREAD_ATTACH: break; case DLL_THREAD_DETACH: break; } /* Returns TRUE on success, FALSE on failure */ return TRUE; } /* LabVIEW created typedefs */ #pragma pack (1) typedef struct { long dimSize; double elt[1]; } TD1; typedef TD1 **dArr; double *Re_zArr, *Im_zArr, *RelErr_Arr, *Re_wArr, *Im_wArr; double complex z, w; int Npts; int i; _declspec(dllexport) void FaddeevaW(dArr x, dArr y, dArr RelErr, dArr Re_w, dArr Im_w); _declspec(dllexport) void FaddeevaW(dArr x, dArr y, dArr RelErr, dArr Re_w, dArr Im_w) { Npts = (*x)->dimSize; Re_zArr = & (*x)->elt[0]; Im_zArr = & (*y)->elt[0]; RelErr_Arr = & (*RelErr)->elt[0]; Re_wArr = & (*Re_w)->elt[0]; Im_wArr = & (*Im_w)->elt[0]; for (i=0; i<Npts; i++) { w = Faddeeva_w((*Re_zArr + *Im_zArr*I), *RelErr_Arr); *Re_wArr = creal(w); *Im_wArr = cimag(w); Re_zArr++; Im_zArr++; RelErr_Arr++; Re_wArr++; Im_wArr++; } } Faddeeva.c Faddeeva.cc Faddeeva.h Quote Link to comment
mhenz Posted September 17, 2020 Report Share Posted September 17, 2020 You created a couple of global variables. This is not thread save. double *Re_zArr, *Im_zArr, *RelErr_Arr, *Re_wArr, *Im_wArr; double complex z, w; int Npts; int i; 1 Quote Link to comment
HeLo Posted September 17, 2020 Author Report Share Posted September 17, 2020 Hi mhenz, thank you very much!!!! I corrected this and - it works 😃. For all, who maybe have a need for it, I attach the corrected code (only the file "Faddeeva.c" was changed). Herbert Faddeeva.zip Quote Link to comment
