timewaster1700 Posted September 29, 2020 Report Posted September 29, 2020 I'm using MGI's Panel Actor. I have an application in which a nested actor launches other nested actors one at a time and inserts them into a subpanel. This works great in dev mode. I have the "Launched Nested" set to Autoshow = T. When I run it in an EXE the panel actors won't display in the subpanel. I thought maybe the autoshow was the problem so I added a message to the nest panel to "Send Show Msg" and it still didn't work. Any ideas on what could be causing these to fail to show in the EXE? The root panel actor and its nested panel start up and display but then when that nested panel tries to launch its own nested panels and display them in its subpanel that's the part that isn't working in the EXE but is in Dev mode. Thanks Quote
