Mike C Posted July 13, 2005 Report Posted July 13, 2005 Does anyone know of a way to programmatically get the application data folder path (i.e. C:\Documents and Settings\username\Application Data) Thanks Quote
Ed Dickens Posted July 13, 2005 Report Posted July 13, 2005 Assuming nobody has changed the default system temporary directory location, you could use the "Temporary Directory" path function, then use the "Build Path" with a relative path of "..\..\Application Data". Example is attached. If you want to go a different path, I believe you can also dig it out of the registry. Ed Download File:post-47-1121271914.vi Quote
