I've recently upgraded a test stands pc motherboard, drives, etc.  The test stand is used for automated testing of products.  The labview environment is downloaded and erased via batch files.  The loading comes from a CD.  This is to verify that the tests are never changed.  After the PC upgrade I'm getting a warning.txt that states the "typedef was expected to be in _____ but was loaded from _____ instead."  The file exist in both places.  If you click ok on the warning.txt., the test runs smoothly.  If you do not notice the warning.txt, because it's in the background until that part of the test starts, then the test will just run continuously until ok is clicked.  Anyone have suggestions?  I cannot post the .vi's or any of the software onto this forum at this time, FYI.
