Bundling a value, a cluster and an array?
It's because your indicator has the string as the last element in the cluster, not the first. If you change your Bundle function to have the string as the 3rd element wired in instead of the 1st, the wiring will work.
I suggest you review the topic of Type Definitions in LabVIEW, where you can define a data type like a cluster in a single location, and use that type definition in all places in your code where you need that type. It helps you avoid situations like the one you describe.
  • Thanks 1
