hardware triggered ai-scan with NI-USB 6009
ramitek
Greetings
has anybody an idea how to scan an analog input of a usb-6009 with an externel hardware trigger (about 300Hz)?
Regards
Michael
I found this in the Manual:
Digital Trigger
When an AI task is defined, you can configure PFI 0 as a digital trigger
input. When the digital trigger is enabled, the AI task waits for a rising edge
on PFI 0 before starting the acquisition. To use ai/Start Trigger with a
digital source, specify PFI 0 as the source and select rising edge.
has someone a example?
Regards
Michael
