Subvi Visibility Handling
Is it possible to display subvi front panels only during certain circumstances (i.e. through invoke nodes)? I cannot find the method responsible for this. I want this to be either a parameter in the subvi or something that alters the subvi's visibility in the main program.
Ok I thought of using property nodes and property execution > showFPonload (when select class > VI Server > VI is selected)... but it doesn't work.
5657[/snapback]
Ok sorry again i got it:
Application Control > Property node
Right click > Select Class > VI Server > VI
Left click on Property > Front Panel Window > Open
Sorry for posting... it was redundant
  • 2 weeks later...
You might want to use the 'openFP' and 'closeFP' VI methods (using an invoke node) instead since they give you more options and according to NI are the recommended method for opening and closing the front panel (see help file on VI methods).
