Sending binary code to virtual com port
Phantom Lord
I'm trying to send two bytes to an FPGA with the vi in attachment. The bytes are sent to a virtual com port which is actually an USB port, but this is handled through an FTDI chip. When two bytes are sent, the FPGA sends 11111111 or
Try wiring a false to "Enable Termination Char" on the configure serial port and add a "bytes at serial port" and use the output of this for the input to the byte count on visa read. You might need to also add a delay between the write and the "bytes at serial port" depending on how quick its response is.
Hope this makes sense!
Kelvin.
Thanks for the response. Did make sense i guess as the time out error dissappeared. But it still not working though. The serial write keeps on only reading one byte. but I guess I know where the error is, just not how to solve it. Think it has something to do with the conversion. I included this VI as well now. Seems the boolean array is converted to only one character instead of two. Looks like it only takes the first byte or something to convert.
Someone else gave me this VI but it was intended for one byte, but I don't know what to change. Any ideas? Meanwhile I keep searching :)
Thanks again
