Function Handler in LabVIEW
Hi guys,
I need to know if is possible, how to obtain a the handler of a callback function written in a C source file which further to be passed as an input parameter to a VI. This VI registers the handler for a function that will call the callabck function when a message is received on the serial channel.
Please find below a small example of how these functions are used in C based applicaitons:
void CallbackFunction(WORD variable1, WORD variable2, long value)
if(variable1 == EXAMPLE_AXIS_ID_001 && variable2 == SRL_ADDRESS)
printf("The value is: %ld [long]\n", value);
void main()
RegisterHandler( &CallbackFunction ); // function from DLL file made by me
while(1)
CheckForMessages(); // function from DLL made by me
return 0;
/*-------- the end of example---------*/
the function prototype is the following:
#ifdef WIN32
typedef void (__stdcall *pfnCallbackRecvDriveMsg)(WORD wAxisID, WORD wAddress, long Value);
#else
typedef void (*pfnCallbackRecvDriveMsg)(WORD wAxisID, WORD wAddress, long Value);
#endif
void TML_EXPORT RegisterHandler(pfnCallbackRecvDriveMsg handler);
Function: Register application's handler.
Input arguments:
pfnCallbackRecvDriveMsg: pointer to handler
Output arguments:
BOOL TML_EXPORT CheckForUnrequestedDriveMessages();
Function: Check if there are new messages and call handler for every message received.
Input arguments:
Output arguments:
return: TRUE if no error; FALSE if error
Is possibel to use the CIN option and how ? :unsure:
If you have further questions please don't hesitate to contact me....
  • 2 months later...
Probably the easiest way to get this into LabVIEW use (under Windows at least) is to incorporate your code into ActiveX or .NET then use events from those. LabVIEW now has the ability to hook onto callbacks from them. Search NI DevZone for articles on examples of how to do this.
