using external Codes in Linux LabVIEW
biorobot
Hi all,
I am a begineer to Labview and Linux. I would like to use external codes in Linux Labview. When I make *.lsb files, I encountered the following error:
/usr/bin/ld: crti.o: No such file: No such file or directory
collect2: ld returned 1 exit status
make: *** [avgv1.lsb] Error 1
Any one knows how to tackle this problem???
Thanks in advance,
"biorobot"
Hi all,
Thanks in advance,
"biorobot"
6038[/snapback]
That's usually caused by not having a dev package installed - ld (the linker) is being called without a path set correctly, or with a missing file (crti.o, one of the basic C runtime object files).
To properly help, it'd be useful to know the following details:
* Labview version
* Linux distribution (Redhat, Debian, Slackware, etc)
* Command you use to make the LSB file
* The output of the "uname -a" command
since Linux can come in many different shapes and forms.
cheers,
Tom
* Labview version
cheers,
Tom
6039[/snapback]
Hi Tom,
Thanks for your prompt answer.
Labview version is 7.1
Linux distribution ---> Debian
I used "make" command to make *.lsb file, and Makefile content is as follows:
# This Makefile was generated automatically by lvmkmf.
CC=gcc-3.4
LD=gcc-3.4
LDFLAGS=-shared
XFLAGS=-fPIC -O
CINDIR=/usr/local/lv71/cintools
CFLAGS=-I$(CINDIR) $(XFLAGS)
CINLIB=$(CINDIR)/libcin.a
MAKEGLUE=$(CINDIR)/makeglueLinux.awk
AS=gcc-3.4 -fPIC -c
.SUFFIXES: .lsb .lsb~ $(SUFFIXES)
# Default rule to create an lsb from a C source file
.c.lsb: ; make $*.o
$(LD) $(LDFLAGS) -o $*.tmp \
$(CINDIR)/cin.o $(XLDFLAGS) $*.o $(CINLIB)
$(CINDIR)/lvsbutil -c $* -t CIN -d "`pwd`"
@rm -f $*.tmp
avgv1.lsb: avgv1.o
$(LD) $(LDFLAGS) -o avgv1.tmp \
$(CINDIR)/cin.o $(XLDFLAGS) avgv1.o $(CINLIB)
$(CINDIR)/lvsbutil -c avgv1 -t CIN -d "`pwd`"
@rm -f avgv1.tmp
clean:
$(RM) -f avgv1.o avgv1.tmp
spotless: clean
$(RM) -f avgv1.lsb
And, finally, uname -a output is
Linux dhcp-eng-staff-505-33 2.6.8-2-386 #1 Thu May 19 17:40:50 JST 2005 i686 GNU/Linux
Thank you for your kind solution.
Rgds,
"biorobot"
Hi Tom,
6040[/snapback]
Okay, looks like you may be missing some of the development packages. Try this:
dpkg-query -s libc6-dev
and if you don't get something like this:
Package: libc6-devStatus: install ok installed
then you're missing the C library development package, which means you need to install it using this:
apt-get install libc6-dev
If that doesn't fix it, let me know.
