Devicenet output to OPC server
I'm posting this for a co-worker:
I am in need of some technical assistance with the FusionUV Lighthammer H10 devicenet communications.
I am able to successfully write and read 4-byte DUINT (Data Word 0 & Data Word 1) from the LH10 using a NI PCI-DNET card according to the document you sent. However, your documentation states there is data out to the 46th byte. My question is: How do I access the data past the 4th byte?
I am using the OPC server from NI, which gives me several data types (see attached document). I have been using the DUINT data type to read the above mentioned word0 & word1. There is a REAL and a LREAL data type as well, but I do not know how to decipher these outputs. Is there some algorithm used to convert this floating point number into something I can use?
Some examples:
At Reset State:
DUINT = 2294016 decimal = 230100 hex (makes sense
SOLVED
After some more research and additional help, the problem is solved. I
will post the details for posterity.
The UDINT data type contains an integer index after it (e.g. UDINT0,
UDINT1, etc). This integer refers to the start byte to read, while the
data type determines the width. So a UDINT4 will read from byte 4 to
byte 7.
I had though this integer was simply for book keeping purposes, but this
was not the case.
Perhaps NI will spend a little more time to document the OPC server
better, and maybe even give some usage examples.
Thank you, Eric
