Kalle Posted October 17, 2005 Report Posted October 17, 2005 Just need to send a 10 digit's string to the RS-232 port. No handshake ore error detection. No need to read from the port, just need to send some decimal numbers to a microprocessor through the RS-232 port. I'm know this is easy, but I cant figure it out.. Kalle Quote
WMassey Posted October 17, 2005 Report Posted October 17, 2005 Just need to send a 10 digit's string to the RS-232 port.No handshake ore error detection. No need to read from the port, just need to send some decimal numbers to a microprocessor through the RS-232 port. I'm know this is easy, but I cant figure it out.. Kalle Yes it is easy and equally easy to figure out if you make the effort to do so... Help --> Find Examples... --> (tab) Search --> (keyword) serial --> (double click) serial --> "Basic Serial Write and Read.vi" Just eliminate the portion that does the reading and add a "Format into string" node to generate the numeric string to send. QED Quote
