progor Posted November 3, 2005 Report Posted November 3, 2005 Hi, could anyone give me advice how to set a case picture. if true picture A (path A), if false picture B (path B). I was trying to solve this problem but with no positive results, that's why I'm asking for help... Download File:post-2324-1131009493.vi Quote
Aitor Solar Posted November 3, 2005 Report Posted November 3, 2005 That won't work. Better try something like this. Saludos, Aitor Quote
progor Posted November 3, 2005 Author Report Posted November 3, 2005 thanks. this is the idea I was searching for. Quote
Mike Ashe Posted November 3, 2005 Report Posted November 3, 2005 Actually, what you tried at first will work, you just need to have the constants. Use the example the previous post showed you to get from jpg files into your picture. On the diagram you can then right click and select make constant. This will give you a proper constant. You can then use those constants. I've added an attached updated version of both techniques showing how you can load from file or use the constants as a "factory default" setting for your images. Nice in that it allows you flexibility for your images.Download File:post-45-1131034607.vi Quote
