picture set
progor
Actually, what you tried at first will work, you just need to have the constants. Use the example the previous post showed you to get from jpg files into your picture. On the diagram you can then right click and select make constant. This will give you a proper constant. You can then use those constants.
I've added an attached updated version of both techniques showing how you can load from file or use the constants as a "factory default" setting for your images. Nice in that it allows you flexibility for your images.Download File:post-45-1131034607.vi
