Visa error
bipin
Crio 9002 rt controller get disconnected in max. There is visa error which i realized later. The controller was working properly. I have tried formating the rt and installing software again.
Bipin.
Hi Vijay,
The crio is detected in max but if i go to Labview and switch the target it does not switch. I tried pinging to the crio rtcontroller but it does not respond.
When i go back to max i find a broken cross against crio. Now i restart crio it gets detected and if i do refresh in max sometime a broken cross appears else if i go to labview as i told earlier it will not switch.
Actually this module was working properly. I had to change the rt startup program as i was making some change in the source code so i deleted the startup.exe from crio rt. After this i started facing this problem.
Hope that the above info help, anyway have you faced similar problem earlier.
Best Regards,
Bipin
