Converting a binary file to ascii
reinato
Hi Reinato:
Can't go through the whole thing, but the basic idea is as follows:
post-1144-1133376903.png?width=400
1) Read four bytes from a file.
2) Type cast the four bytes as a single.
3) Format the single into a string.
I've left lots of details for you to work out-- put all this in a loop, with the file refnum wired to a shift register so you get more than just the first data point, might have to skip some header info in your file, might want to do something with the formatted data (Write to another file?), etc. but this should point you in the general direction.
For some types of files, there might be an easier way to do this, but the approach I've shown above is pretty general, you should be able to adapt it to whatever your needs are-- some of the easier approaches might be less versatile.
Hope this helps at least a little, Best Regards, Louis
One more point--
Some possibility, depending on where the data came from, that you might have to reverse the order of the bytes after you read them & before you type cast them as single. If so, look under String Functions>Addition String Functions> reverse string.
Louis
