Louis Manfredi Posted December 6, 2005 Report Posted December 6, 2005 Hi Folks: Here is an obscure little feature (bug?) with LV8.0. If you have a front panel control which is an array of Waveforms, and if you click to edit on one of the elements of the data array within one of the waveform elements, all the elements get a cursor displayed. The cursor only blinks in the element you actually selected, and when you finish the edit, the cursor only goes away in the element you selected, see below. A little obscure & harmless? Only causes slight confusion while manually editing a waveform control, which is only likely to happen when testing a sub-vi, (I can't think of any other reason to manually edit an array of waveform type) but a bug none the less, and perhaps there's some less benign manifestation of the underlying problem. Best Regards, Louis Quote
