RT module freeze upon deployment
The new architecture that enables seeing the front panels from an RT target as the same time as local VIs is great, but it has problems. If you forgot to explicitely "Connect" to your RT target (ETS) and attempt to deploy a VI to it, LabVIEW (on XP) freezes. Relaunching the app is sufficient to fix it from my end. Or maybe about 3 lines of code on NI's end...
(The absence of a "Run" command from the project list's contextual menu is inexplicable.)
Guillaume Lessard
