Joost van Hamond Posted January 6, 2006 Report Posted January 6, 2006 Hello all, I've the following problem: I read data out of a multimeter. This multimeter is sending 9 bytes of information each time: _11.534 where _ is normally an empty space (is reserved for a minus when the value is negative) and are delimiters. After a while, the sequence of the string changes (no idea how!! :headbang: ). So instead of reading _11.534, I read, for example: .534_11 Normally the value is 11.534, but now my program thinks the value is 0.534 which is wrong. Does anyone know how this could happen? Or does anyone have had the same problem? Please let me know..... Thanks! Joost Quote
WMassey Posted January 6, 2006 Report Posted January 6, 2006 It looks to me like you are getting the last portion of one message and the first portion of the next. How are you deciding when it is time to read the string? I assume that this is RS-232 communications and you are using the VISA serial-port VIs to setup & control the communications? Correct? Have you setup the VISA Configure Serial Port VI to terminate the read on the second one of your delimiters (possibly a linefeed character)? You can also set this up using a VISA property node before the read operation. See the attached example (LV v7.1.1). I just noticed that you have LV v6.1 so I have also attached a 6.1 version of the example in a zip file. If you are doing all this, then I have no idea why you are getting the results you are seeing. Download File:post-2800-1136554812.vi Download File:post-2800-1136555775.zip Quote
Joost van Hamond Posted January 6, 2006 Report Posted January 6, 2006 Hi, Thanks for your response.... I am also quite sure that I read the last portion of one message and the first portion of the next.... You are right with RS232, but I'm not using VISA. I use the Serial Port Initializing VI and the Serial Port Read VI. When the program starts running, it initializes the serial port. When no error is occurred, the program runs a while loop. In this loop it takes 9 bytes of the buffer every time. This keeps on running till there is an error or I press the stop button. I now changed my program by moving the Serial Port Initializing VI into the while loop. So the serial port will be initialized every time before reading a value from the buffer. This is not really what I want, but it is working. But I'm still interested why my other solution is not working... Quote
Megavolt Posted January 7, 2006 Report Posted January 7, 2006 Just had this problem today. The instrument was sending extra messages which would be in the read buffer when went to read the number of characters I was expecting for a response. I turned off the messages, but I was still having the same issue you are having. I used the FLUSH READ BUFFER before every Command write and response read and have not had a problem. Quote
oskarbosch Posted January 9, 2006 Author Report Posted January 9, 2006 When reading the serial port, always try to: - determine what the end of the message is. NEVER read a fixed number of bytes. - Don't reinitialize the serial port all the time. Not good practice - flush the buffer of "old" data if the instrument could send out other message (as indicated by the previous post). - Always program timeout mechanism, so you don't end up waiting indefinite for your termination character (what if it never arrives???) you indicate that you always read 9 bytes. Change this read mechanism to read until the termination byte (on of your squares, preferable the second one) is received (this will typically be a linefeed (0x0A)). So you'll have to perform you read in a separate VI with its own while loop, where you read a byte at a time until you read the termination character. Hope this helps, Oskar Quote
