Location of "LabVIEW Data" folder
OK, so when I change the location of the "LabVIEW Data" folder using the development environment options, the location changes sure enough - until I run an executable. Then the "LabVIEW Data" folder again gets created in the "My Documents" folder. It's almost as if the run-time engine has a data path of its own...
Two questions:
1) Anyone else able to replicate this on their machines or under a different version of LV or the RTE (I'm using LV 8)?
2) Anyone know if there's a separate .ini for the run-time engine (or some other way to keep an executable from creating this folder in My Documents)?
As usually happens when I post something, the answer comes to me shortly after clicking the "Post New Topic" button...
I just added the "DefaultDataFileLocation=..." tag to the .ini file of the built executable, and that did the trick. Kind of a pain to have to do it for every built app, but...
