Limit the Char
Rhino
Dear All,
In h/w interface, user can select the modes by pressing the switches. There are 5 main modes. Each main mode has 8 sub mode. If user select the main mode 1 and sub mode 5 ( by selecting the h/w Switch interfaced with DIO lines), the corresponding 24 led names, 24 switch names and ROT,POTname ...etc has sent to LCD for display. If user changes the mode, the name of all controls of that particular mode will also sent to lcd for display.
So i need to collect the 24 led names, 24 switch names, 2 rot switch name. 4 pot name and sub mode name from the user for 40 modes(5 main mode * 8 sub mode). The name is restricted to 5 char.
I am waiting for your reply, The key filter does not restrict to 5 char, if i press any key continuously. Kindly spend some time to fix this.
I attached my latest VI.
regards,
Karthik
Download File:post-3907-1137559246.zip
