labview & mysql performance
Hi
i'm testing LabSQL with mysql 4 due ODBC driver on Windows XP2
I try different types of simple query but i report poor performance
1000 select of INT about 900ms
using Query browser i execute he same query in about 15 ms!
i don't know why, maybe a bug in ODBC.
Do you have any feedback on performance?
Bye,
Alessandro.
Hi
Bye,
Alessandro.
Yes, well this is a known (to me) bottleneck with the LabSQL stuff. There are changes you have to make to some VI's that may speed things up. Here are the two VI's before:
post-2-1138082105.gif?width=400
And here are the two VI's after:
post-2-1138082278.gif?width=400
Thank you Michael
i try the modify suggested by you and its work fine.
Now i have 600ms for 1000 select and about 400ms for 1000 update.
Bye,
Alessandro.
Thank you Michael
Bye,
Alessandro.
That is still slow. What SQL statement are you using? Also, have you indexed your table?
I just did a simple test with: SELECT * FROM `databasename`.`tablename` of 1000 records and it takes: 15ms. :yes:
Michael i don't execute a single select of 1000 rows but 1000 select of one field...sure in the first case i obtain a time of 15 ms similar to your.
The actual performance are good for my needs.
Now my problem is on ADO callback i need to generate a callback when a commit operetion occur on DB.
I wrote this simple VI for register the callback but dosen't work at all (no callback is fire)
post-399-1138206754.jpg?width=400
Do you have experience on this?
Thanks,
Alessandro.
  • 3 years later...
I just did a simple test with: SELECT * FROM `databasename`.`tablename` of 1000 records and it takes: 15ms. yes.gif
Using the changes mentioned and with the original code when i query for 632 columns i get 4000 rows in about 2-3 mins ....y is that so?? is it bcoz of the number of columns ??
Edited by Robinson
