How close Panel without "Save changes" dialog box?
I use VI template for reentrant execution. When a template VI is loaded, it creates a copy of itself in memory. When attempt I close loaded copy of vit file over clicking on right-top corner X appears Save changes dialog box. Is it possible to close running Vi without Save changes dialog box?
Thanks
I've done this by using an event structure to trigger on a "Panel Close?" (notice the "?") event and set the "Discard?" input to true. This allows you to stop the VI programmatically when the close button is clicked. I also use the attached piece of code to allow an instance of a template VI to close itself without the "Save Changes" dialog.
Hope this helps.
post-1591-1139500204.jpg?width=400
