Anyone here have used Matlab's DAQ Toolbox?
I'm trying the DAQ toolbox in Matlab, it supports NI cards so I gave it a try. Anyway I haven't used before Labview and what I need to do is simple.
I dunno if there are people here that also has used this tool. But hoping yes, I have a question.
Is there a way to force a SampleRate so I don't recieve an error that my device doesn't support the sampling rate I specify? Actually the card supports the SampleRate I'm willing to use, it works fine when I tests panels with that sample rate.
What I want to do is to send a bit to activate a sonar and read back the echo signal by an analog port. I'm actually doing it with Matlab, but the problem is the sample rate. Do you think I can learn enough Labview in some hours to just make that, would it be worth?
