B Chavez Posted March 30, 2006 Report Posted March 30, 2006 Is there a way to change the color of the error cluster wires (or any cluster wires for that matter) on the block diagram? I have seen images posted that have green error cluster wires. Example: Quote
S59X Posted March 30, 2006 Report Posted March 30, 2006 B Chavez said: Is there a way to change the color of the error cluster wires (or any cluster wires for that matter) on the block diagram? I have seen images posted that have green error cluster wires.Example: Put the following line into labview.ini funkyerrClustWire=True It works in LV7.0, I don't know about LV8, since I don't use it (yet). Quote
B Chavez Posted March 30, 2006 Author Report Posted March 30, 2006 No wonder I couldn't find it in the help. Thanks! Quote
Guillaume Lessard Posted April 4, 2006 Report Posted April 4, 2006 rbogomir said: Put the following line into labview.inifunkyerrClustWire=True It works in LV7.0, I don't know about LV8, since I don't use it (yet). I tried it in LV8.0.1. It works, but now all my VIs that use error wires are difficult to open until I manage to save them again. The difficulty: "This VI was changed on disk since last opened by LabVIEW. Revert?" followed by "Discard changes?". Clicking cancel in either dialog results in the VI not being opened. In some cases it's a pretty strange succession of those two boxes until somehow it all opens. Edit: Rebooting the computer seems to have fixed this. Not that it makes sense. Quote
