video aqisition
hello
I know that I am already to be annoying, but it is possible to tell me that what mean the errors that are give in the program.
the program gives two mistakes about the bad connection of the wires?
once again thanks and excuse for the fact of being annoying .
Right click on the activeX control on the front panel and select videocapx as your activex control. Then go to each property node and invoke node and reselect them from the list of possibilities avaliable in the list of properties and methods. Don't change the property or method that is listed, just reselect it. This error comes up because we are using two different versions of the videocapx activex control.
