cocowk Posted April 7, 2006 Report Posted April 7, 2006 Hi everybody, Sorry for my poor English, I'm a french student in internship using Labview for the first time. I want to simulate a random binary frame. I found functions in Labview that can generate sine waveforms and square waveforms but using a periode. In my case, I want this signal to be square and to represent for example a binary sequence measured on a bus line such as CAN bus. Is there a vi in Labview that realise this? Or do we have to generate this signal ourselves? Then, here is my problem: I made a vi that generate this type of signal, and I wanted to measure the signal pulse width and its rising and falling times. But I get an error message like "Amplitude of the signal is 0"... I join the VI to this message for you to see my errors... Thanks Download File:post-4586-1144395131.vi Quote
MatthewHarrison Posted April 7, 2006 Report Posted April 7, 2006 I'm not sure I understand what kind of pulse generation you really want, but perhaps the edited attachment will help you out. I don't think you were actually generating a pulse train the way you were doing it. You were just generating a single sample. -Matthew Harrison Download File:post-811-1144401277.vi Quote
cocowk Posted April 7, 2006 Author Report Posted April 7, 2006 I'm not sure I understand what kind of pulse generation you really want, but perhaps the edited attachment will help you out. I don't think you were actually generating a pulse train the way you were doing it. You were just generating a single sample.-Matthew Harrison Download File:post-811-1144401277.vi Thank you for your answer. It's not exactly what I wanted to do. I want the measurements to be done continuously that's why I put a while loop and not a for loop. But perhaps is it impossible. Your answer helped me, and I will work on it to try to get what I want. Thank you. Quote
