Program calling Active-x Object Doesn't Execute Correctly When Built to an Exe
I'm fairly sure that this topic must have come up before...
I'm running LV8 and developing an application that uses an existing registered active-x object. The program executes correctly when running from LV8 (or LV7.1). Once the program is built to an exe, it crashes at the call to the active-x initialization.
I've heard secondhand information that some active-x objects are problematic if they themselves call other active-x objects in certain instances.
Is there a document that describes how the Labview development environment differs from the that when the application is "built" to an exe ?
Thanks,
John
