philips Posted April 21, 2006 Report Posted April 21, 2006 Again demonstrating my ignorance... I am using a mapping app on a PDA called OziExplorerCE. THis comes with a simple API which I would like to use from LabVIEW - you can look at it here http://64.71.184.220/ozice/ozice_api_docs.html All I need to do is 1. Write data to a text file (easy - even I can do that!) 2. "Send a message to OziExplorer with the correct command number to do the Command" An example of this from VB is: Result = SendMessage(OziWindow, WM_USER + 5, Me.hwnd, 101) How can I do this from LV PDA 7.1? I had a look at an example on the NI site here: http://sine.ni.com/apps/we/niepd_web_displ...source=External This uses a Call Library Function Node which appears simple, but it appears to need a whole heap of complexity with the DLL & Visual c++ code associated with it. Is it really this complicated? Is there a simple way of doing it? Any pointers greatfully received. Cheers, Phil Quote
