Is this array empty, or isn't it?!?
It is possible to have a 0xn or an nx0 array in LabVIEW, where n is a non-zero number. It has to do with the way the dimension data is stored. The easiest way I know to reproduce this is to take three empty 1D arrays, wire them all into a Build Array, and the size of the resulting 2D array is 3x0. If any of the dimensions of an array are zero, you have an empty array. In LabVIEW 7.x and previous, the best way to determine if an array is empty is to do an Array Size, and wire the resulting array of dimensions to Multiply Array Elements to see if you get zero. In LabVIEW 8.0 and later, you can simply wire your array into the Empty Array? function in the comparison palette.
-D
P.S. - This is not a bug. :)
Awww man - you answered too quickly! :D
