Notifiers and Parallel While Loops
Hi avid LV users!
I want to verify if it's possible to run a top level vi
with notifiers and 16 parallel while loops? and the control to stop the
while loop is a global bool var...
however the while loop can only be activated by a notifier.
After the notifier is fired, it can run the loop, til it the Global Stop Var is
clicked
thanks!
Hi;
In a nut shell, the answer is yes !
However, you cannot enable/disable while loops dynamically...
You can however have them idle till they receive some notifier to execute.
You'll also need to have a state to stop the loop if you don't
want to put a time out on the wait for notifier function.
Without a timeout, this loop will wait forever and won't loop till...
This type of structure is essentially a state machine.
So look up labview help on state machines...
good luck
Walters
Hi avid LV users!
clicked
thanks!
Hi;
good luck
Walters
You can do it without timeout. The "wait on notification" returns if the notification is fired or when destroyed. On last the primitive "wait on notification" returns with an error. Use it for your advantage and surround your work in the loop with an if state. When no error is returned by the notifier, then do the work and loop back, when an error is returned do nothing and stop the loop. Repeat this for every loop. Now have a 17th loop with the event structure that waits for user interaction to either fire a notification or when stop button is pressed. In this state release all notifiers.
Download File:post-253-1148388229.vi
