How to allow user to change plot name?
Does anyone know how to programmatically change plot names where there are multiple plots displayed on one chart? I can change the first one only using property Plot.Name, but it only handles the first one. Any suggestions???
You need to use the Active Plot property to select each plot. By default the active plot is the first one, which is why changing Plot.Name changes the first one. If you select a different Active Plot, the same property will change the name of the selected plot.
David
The Plot.Name property deals with the "Active Plot" (which is, by default, 0). Set the Active.Plot property to 1 (or whichever plot you want to change) and then use the Plot.Name property. This can be done several times in one property node, as LabVIEW executes them in top-down order.
