DAQ triggering/synchronizing
tibobo
I'm trying to use DAQ S 6143 and M 6224 simultaneously using DAQmx base.
I should admit I'm a little bit frustrated since I didn't managed to do anything !... :
- Using RTSI cable to share sample clock using daqmx base export signal vi, nothing works.
- Using "daqmx base start trigger (analog edge)" to do triggering (start an acquisition when an analog input cross a level) on a single device, nothing works. (example below).
Could somebody have any successful experience to share in the field of triggering/synchronizing on mac os x or should I abandon all my hopes...?
For now, I'll go to bed !
Thanks
Boris
Download File:post-4507-1147804417.vi
Hi Tibras
have you tried to test your board with more simple aquisition task ?
Yes, I'm using simple acquisition tasks for more than one year on both boards, but without hardware triggering. Now I have to synchronize acquisition between the two cards and that's why I get to try sample clock sharing with RTSI bus. It didn't work so I tried using triggering which didn't work too :throwpc: .
The fact that RTSI doesn't work is not surprising for me (since it's written here :
http://zone.ni.com/devzone/conceptd.nsf/we...256FB1007227EC).
The fact that triggering doesn't work is more surprising.
Did you ever tried synchronising or triggering with mac os x ?
Boris
unfortunately not :(
just continious analog acquisition…
in couple weeks, I've no time for test but later…
I keep you in touch…
