how to auto-overwrite data in specify file path?
hi,
I came across with problem when saving a file to a specify file path.
when my data is saved in a file path, when a new set of data is being entered, a window pop up asking: "replace existing c:\file_name?". and I have to press 'ok' button to replace it. what I want is that I want the new data to automatically replace into the same file path without that window poping out.
so what should I do to eliminate that window pop-up?
example on this kind of problem is much appreciated.
thanks.. :(
hi,
thanks.. :(
No matter whether U read labview user manual or not before u start using it, U got to read this before you start posting here...
Guys here will not do the homework problems for U, :nono: even if they know the how to....isn't it cruel :rolleyes:
