Trouble with Frontpanel Binding Mass Configuration
CQD
:( Again I am having trouble....
When using the Frontpanel Binding Mass Configuration some Variables are updated, some are not. First I Export to a Textfile and change e.g. the IP Adress of the Server hosting the Shared Variables for each variable. Then, after importing the changed Textfile all changes seem to be updated in the config. But pushing the Apply Button all or some changes are reverted. Where the changes did apply, I checked the Properties/Databinding. The Variable was still bound to a Project Item with a different IP (the Variable on the Server) what is from my point of view not possible. :thumbdown:
Sounds like a Bug....
Anybody ran into that problem?
