supriyav Posted June 16, 2006 Report Posted June 16, 2006 Hello, I need clarification regarding setting and getting the time. I'm working with LabVIEW 6.1 i need to frame response for severel commands.In that 2 of the commands are time related. In one command i need to set the time, that time value will be given through serial interface as an array. The other command will be given after the previous command.In the second command i need to read all the channels and i need to frame the response packet in that packet one of the information is time (hh:mm:ss).This time is the one with respect to the first command. i.e if the 1st command sets the time as 10:10:10 and the 2nd command is executed after 20 Minutes, then the time in the second command's response should be 10:30:10. Note: Both the Command and the Response commands are array. Pls do the needful Thankyou and regards SupriyaV Quote
