Double-Click of VI after "create subvi" action doesn't open VI
Double-Click of VI after "create subvi" action doesn't open VI.
If you use the "Edit >> Create SubVI" function from menu's and then double-click the new VI icon that was created, the front panel doesn't open. However, if you nudge the icon 1 pixel, it now works.
It seems to be related to editing the VI and saving it or changing the connector pane. You must do this before trying the double-click. I haven't had time to narow this down.
Can others confirm this?
I can't reproduce it in 8.0. Is there anything peculiar (VISA I/O refnums, matrix datatype, etc.) in the code you are turning into a subVI?
-D
