Hellfire Posted June 22, 2006 Report Posted June 22, 2006 Has anybody knowledge about the sourceforge projekt LabXML? There are two toolkits, first using the MSXML core services and second LibXML of the Gnome projekt. So my question is, which compilation ist better working in LabVIEW? to check out what i mean http://labxml.sourceforge.net/ In my projekt i have to save CCD-Cam Images , voltage measurements, positions etc. structured, so i will do this with XML-Format and the option to connect these files to a database. Therefore my question which toolkit will be better working? thanks Quote
Dirk J. Posted June 22, 2006 Report Posted June 22, 2006 I've been using the MSXML parser through ActiveX, and for 99% of my needs, it works perfectly fine. It seems to be able to parse large XML documents (up to a few MB) pretty fast. I've been experimenting with the .NET implementation, but that turned out to be about 10 times as slow, which is unfortunate because it has some more options. I'm not familiar with the LibXML, so can't give you information there... Quote
