C++ main function in LabVIEW
I'm quite new in LabVIEW. I must import some c++ code in LabVIEW in order to make a bitstream player plays or not a stream.
My problem is that this code uses the main function with 2 arguments. So, the first argument in this function is int, the second one is char* argv[].
My program, as I assume my CLF, will take as first argument the bit rate and as second, the name of the stream.
I wonder how the interpretation of the main function will be by LabVIEW as it's a particular one in cpp.
Thanks
(I'm using LabVIEW 7.1, my stream player is on a PCI card and my goal is to control it from LabVIEW.
If anyone got another idea than importing c++ API, please, don't be shy!!!)
