a_biotica Posted July 17, 2006 Report Posted July 17, 2006 :headbang: Hi LABVIEW Gurus. I'm a newbie on Labview and I'm using Labview Version 8.0. Using on the example from Pattern Matching which analyze an opened image, I'm trying to modify the code which uses a camera. There are three buttons (Capture Image, Learn Template, & Search), Once the Capture image is click, Camera Image will be save to Image control. I have an error once I click the "Learn Template" button which indicates error # -1074395234 (The template image is too small) from the IMAQ LEARN PATTERN 2 (Screenshot is included in the attachment). Anyone can help me to fix this problem. I also attached my Labview VI for your reference. Thanks. :worship: Download File:post-5601-1153125717.zip Quote
JianYun.Li Posted August 7, 2006 Report Posted August 7, 2006 OK, i am also doing something research about image processing, i tried to find out your error, but i can't open your .VI totally, could you submit once? Quote
