plneo Posted July 26, 2006 Report Posted July 26, 2006 Hi everyone, I wonder if you have such problems before? When I load the code resources into a CIN, I received the following warning message and it reads: MV_Open.vi - The shared library expected to be at "C:\Program Files\MATRIX VISION\mvLabVIEW SDK\MV_Open\MV_Open.lsb" was loaded from "NULL". The 'Run' icon also disappears and I am unable to do anything with the VI. Does anyone has a walk-around for this problem? The .lsb file is generated using MS Visual C++ 6.0 and I am using LabView 8.0 at the moment. Thanks. Quote
