Florentj Posted August 11, 2006 Report Posted August 11, 2006 Hi, here is simple question from a beginner: How do I add/remove buttons on the same front panel in "real time". Let's say I have a main front panel running, then a condition is met and I would like to offer the user some options. How can I make these new options (buttons) appear on the same front panel (no new dialog). Any help is much appreciated, Juan Quote
Ulrich Posted August 11, 2006 Report Posted August 11, 2006 Hi,here is simple question from a beginner: How do I add/remove buttons on the same front panel in "real time". Let's say I have a main front panel running, then a condition is met and I would like to offer the user some options. How can I make these new options (buttons) appear on the same front panel (no new dialog). Any help is much appreciated, Juan Hi Juan, you can create a property node from the buttons with the property "visible" (true/false). This should help. have a nice day Ulrich Quote
Louis Manfredi Posted August 11, 2006 Report Posted August 11, 2006 Hi Juan: Also, think about possibly using the enabled property node to set the inactive controls to the "Disabled and Greyed" state-- from the UI point of view better than simply making the control disappear-- the user knows that the action is sometimes, but not presently, an option. Best Regards, Louis [edit] P.S. Welcome to LAVA! Quote
