atk_nut Posted August 17, 2006 Report Posted August 17, 2006 I'm trying to generate a sine wave on 6 channels at 60hz. I want to "smoothly" transition to 50Hz. The update rate is 60,000 points per second (that should give 1000 points per cycle at 60Hz.) I generate a buffer of 1000 points for 60 Hz, then write the buffer of 1200 points (50 Hz) at the same update rate. However, the signal stays at 60Hz. until I reset the clock. I'm getting stumped. Any ideas? I've attached some code. Download File:post-1336-1155844390.vi Quote
Dan Press Posted August 30, 2006 Report Posted August 30, 2006 There's a decent NI example that can be found here. Quote
