Aitor Solar Posted August 31, 2006 Report Posted August 31, 2006 I haven't seen this info elsewhere and I think it can be useful. Pattern code - Number of connectors 4800 - 1 4801 - 2 4802 - 3 4803 - 3 4804 - 4 4805 - 4 4806 - 4 4807 - 5 4808 - 5 4809 - 6 4810 - 6 4811 - 7 4812 - 8 4813 - 9 4814 - 10 4815 - 12 4816 - 6 4817 - 7 4818 - 8 4819 - 9 4820 - 10 4821 - 11 4822 - 9 4823 - 6 4824 - 7 4825 - 8 4826 - 10 4827 - 7 4828 - 8 4829 - 11 4830 - 4 4831 - 5 4832 - 6 4833 - 16 4834 - 20 4835 - 28 Number of connectors - Pattern codes 1 - 4800 2 - 4801 3 - 4802, 4803 4 - 4804, 4805, 4806, 4830 5 - 4807, 4808, 4831 6 - 4809, 4810, 4816, 4823, 4832 7 - 4811, 4817, 4824, 4827 8 - 4812, 4818, 4825, 4828 9 - 4813, 4819, 4822 10 - 4814, 4820, 4826 11 - 4821, 4829 12 - 4815 16 - 4833 20 - 4834 28 - 4835 Saludos, Aitor Quote
Mark Balla Posted August 31, 2006 Report Posted August 31, 2006 Aitor Solar said: I haven't seen this info elsewhere and I think it can be useful. Here is a ring control that I created a while back for my subvi fixer Download File:post-584-1157028237.ctl Quote
Darren Posted August 31, 2006 Report Posted August 31, 2006 And here's a link to one of my Weekly Nuggets on the NI Discussion Forums where I talk about customizing the connector pane of new VIs in LabVIEW 8.0 and later. It also includes a VI that returns the proper 4-digit connector pane ID given a specific pattern. http://forums.ni.com/ni/board/message?boar...ssage.id=171666 -D Quote
Aitor Solar Posted August 31, 2006 Author Report Posted August 31, 2006 Of course, I should have known that just because I haven't see it, doesn't mean is not everywhere :-D. What would be really great is a way to set a customised pattern in a VI, instead the predefined ones. For example, defining hot zones in a 32x32 square. As far as I know, only Xnodes can do that, but they are pretty complex for just something like that :-( Saludos, Aitor Quote
Mike Ashe Posted August 31, 2006 Report Posted August 31, 2006 Awesome little nuggets, and with replies, controls, a graphic of the patterns. Thanks guys, more reason to stick to LAVA! Quote
Aitor Solar Posted September 4, 2006 Author Report Posted September 4, 2006 Now, the connector order for each pattern (which one is the 0, the 1, etc) is pretty chaotic. Sometimes it starts from bottom-right, some from top-left... Is a mess when you are connecting dinamically created VIs Saludos, Aitor Quote
Mark Balla Posted September 12, 2006 Report Posted September 12, 2006 Aitor Solar said: Now, the connector order for each pattern (which one is the 0, the 1, etc) is pretty chaotic. Sometimes it starts from bottom-right, some from top-left... Is a mess when you are connecting dinamically created VIs Saludos, Aitor I've also created vis that figure this numbering system out in the Subvi Fixer Base on the position the index is placed in a cluster that represents the pattern. Quote
