Unable to create task from within a *.lvproj
LoTek
Hi specialists and such folks,
I am generally a happy LabVIEW/DAQmx user, but currently I am running mad about what I take it as a linking/konfiguration problem between MAX/DAQmx and LabVIEW Projects.
The most informative thing I can get is an error while simply creating a task in my code. I've snipped it below, note the hint to directly contact NI Support.
-->snip<----------------------
Status TRUE
Code -229665
Text
Error -229665 occurred at DAQmx Create Channel (AI-Voltage-Basic).vi:1
Possible reason(s):
Internal Software Error occurred in MIG software. Please contact National Instruments Support.
Task Name: _unnamedTask<28>
I did some further testing and found out that this error code results at any access to a task even a task already defined in the MAX.
This problem occurs only when I am within any LabVIEW Project (*.lvproj) environment. I mean the same code works very well when I just double click the VI in the explorer. Attaching it to any project immediately runs it mad resulting in the above error.
I cannot create a task, channel or scale from within a project, too. It happens that just noting happens, no dialog or something else. That's why I think this might be a konfiguration problem or a linkking problem between projects and DAQmx.
OK, I've tried a complete uninstall of all LabVIEW and DAQmx stuff. This didn't help. LabVIEW Support couldn't reproduce this unfortionately.
I am looking forward here for someone having heard the error code (couldn'd find it myself yet) or knowing about this 'MIG Software' stuff.
Well, if anybody has read until here I very much would appreciate any usefull idea wich prevents me from reinstalling the whole computer. (Which might result to the same problem as this was a brand new one.)
I am using LabVIEW 8.20 with DAQmx 8.3, NI-FGEN 2.4 and NI-SCOPE 3.1.
  • 3 weeks later...
  • 2 weeks later...
