LabVIEW 7.1.1 File palette for 8.x
Salut.
If you want to have the LabVIEW 7.1.1 file subpalette, follow the instructions :
1- Run UVI_MenuVIEW.vi (attached)
2- open LabVIEW-->Menu-->Tools-->Advanced-->Edit Palette Set...
3- Browse into the programming subpalette
4- Right click on the subpalette right of the File I/O subpalette(or any other chosen location) and select Insert-->subpalette...
5- Select "Link to an existing palette file (.mnu), click ok
6- Select C:\Documents and Settings\%user\My Documents\LabVIEW Data\8.x\Palettes\menus\Categories\Programming\_File IO\LV7.1.1_file.mnu
7- Click ok
8- click save changes (if you have the option "preview changes before saving" active, you will get the message below, click continue)
post-731-1157219136.jpg?width=400
Download File:post-731-1157219127.vi
