Jacemdom Posted September 6, 2006 Report Posted September 6, 2006 Salut. I am using Perforce for SCC. I have a to enter a password to enter into the depot. After a certain amount of time, i have to reenter that password. When the password is not valid anymore, LV acts like if there was no SCC around!!! Is it possible to make it ask for the password? Quote
gmart Posted September 6, 2006 Report Posted September 6, 2006 Salut.I am using Perforce for SCC. I have a to enter a password to enter into the depot. After a certain amount of time, i have to reenter that password. When the password is not valid anymore, LV acts like if there was no SCC around!!! Is it possible to make it ask for the password? Are you using the Perforce Command Line provider in LabVIEW or Perforce SCM (LabVIEW 8.2)? Are you using the default settings option when you configure source control or are you specifying the port, user, and client? If you are specifying the information, there is an entry for password. I believe this should work. There is another concept called "tickets" that Perforce uses, that the Perforce Command Line provider does not currently support. Quote
