Search string bug?
bwgames
I have a VI (screenshot attached) that works fine in highlight execution mode, the search string returns 0, yet when I run it normally, it doesn't match.
Screenshot contains probes for the result of the search string and the read buffer. As far as I can see, it should be returning 0, not -1, and indeed it does in highlight execution??
Using LV 8.0
:oops:
It works fine now, if I reduce the number of !!!'s in the search string, still doesn't really explain why it works in highlight execution only with the original number though...
post-5988-1157619635.jpg?width=400
As far as I can see (count!) you have 24 chars in your read buffer and 25 in the search pattern, thats why -1 is returned.
The reason this might work when you trace it, is most likely that your VISA read VI gets to read more data, as execution is delayed.
I don't think it's a problem with the string compare function.
-Mikkel :)
